I'm designing a BMS for 15Ah LiFePO4 cells with shunt resistor balancing, and it's not clear how the BMS should manage the balancing period around the end of charging.
I have 2 options:
1.
When the voltage of any cell reaches 3.65V, then apply its shunt and switch off the charge current.
When the voltage decreases to 3.55V, then disconnect the shunt, and if all cells are below 3.55V, then switch on the charge current.
2.
When the voltage of any cell reaches 3.65V, then apply its shunt and reduce the charge current to a few 100mA that maintains the cell voltage. This current should be 3.65V/Rshunt, or a bit less.
When the voltage decreases to 3.55V, then disconnect the shunt. If all cells are below 3.55V, then increase the charge current to the original high level (e.g. 10A).
I think option 1 would balance the cells faster, but switching the cells at high current does not seem to be safe to me. Not sure, but maybe it can reduce the life of the cells.
Option 2 is is more "soft", because low current charges the cells which did not reach 3.65V yet. Despite the low current, the voltage of the cells with shunt ON would decrease to 3.55V after some time (can be few seconds or minutes), then high current switches on, but at a lower frequency than in option 1. The balancing probably takes more time in this case.
Any idea which one is better, or something else?
Thanks,
Peter
I have 2 options:
1.
2.
Thanks,
Peter
