no, you are totally wrong on this. you can watch the lecture on the tesla user's website given by that professor who has his grad student as head of battery research for tesla now.
mitchji had pulled it down here once and i tried and tried to get people to watch it but nobody did so these theories about cycle life which have no basis in good science have continued. if people would just listen to that lecture there would not be all of these misinforming statements about final voltage and depth of charge and discharge with respect to cycle life.
in that lecture he explains why the legacy research on cycle life is explained by his demonstrations of the change in capacity each cycle that he was able to measure with his micro ammeters during charge and discharge to prove how effective some additives are and how the cycle life is dependent on the rate of growth of the contaminated clogging layer of the SEI.
if you have not watched it yet then you should before making more comments without fundamental research to support it as he did. if you watched it and do not understand that cycle life is dependent on the length of time and temperature at full charge, then watch it again.
