BMS Compatibility
TheRam
New here
America
Hello, I have a Jk bms that was recommended to me by some other people in this forum. It is Jk bms B2A24S. It says that it can handle from 8 to 24 cells in series. However, I had some things change and I now have six cells in series. Would it be fine to use this bms for my purposes? If not would I be able to use this bms: JKBMS Smart BMS with Heating, CAN, RS485, 4S-8S 12V-24V 200A 2A Active Balance (linked below). It has 24v, but my battery would be 25.6v as it is six cells in series with each having 4.2 of max voltage and a nominal voltage of 3.6 volts. Would this be ok instead? If both of these are bad options, what would be a good substitute? Any answers are appreciated!
BMS:
https://www.amazon.com/JKBMS-24V-72...8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1BMS on Amazon:
