iovaykind
Figured it'd be much quicker to ask the question here and get a response than through email with the supplier who can barely speak english.
I got this BMS:
http://item.taobao.com/item.htm?id=15894708275
Anyway, the connections seemed simple enough, the negative of the battery goes to B- and the P- goes to the negative of the charger. All balance wires are hooked up correctly and I can read each individual cell voltage through the legs on the BMS. However, when I plug in the charger, it doesn't start charging. Charger charges fine when I connect straight to the pack, just not through the BMS, so I know its not an issue with the charger.
I use a bulk charger, similar to the BMS battery ones.
Here are some symptoms..
Plugging in charger + to battery + and then charger - to P- nothing happens. I think check the voltage of the charger, and it drops from 66v (16s lipo) to 30v and stays there unless I unplug the charger from the wall and wait a little bit and plug it back in.
There is no continuity between P- and B- on the BMS itself, and all cells are within 3.7-3.9v each.
Anyone have a similar BMS and could give me ideas as to what's going on?
I got this BMS:
