ElectricGod
I pulled up the HY3410 mosfets and moved them over to the C- buss. I had a bunch of AOT290 mosfets that I pulled off a dead BMS. They already had the center legs cut out of them which was exactly what I needed for the BMS. I left all the copper reinforcing where it was and then added wire to both sides of P-. The original .004 ohm .5w shunts came out and were replaced with 10 .005 ohm 2 watt shunts. I'll need to reset the shunt value so it reads current correctly.
