I bought a used ebike 350w 36v cheap. The battery is good i tested it and it went for about 20 miles, But i went down all the way to get all the juice out (test), and the battery shuts down at 30v. But when i try charging it, it seems it wont take charge. So i knew the bms shuts completly down at 30v. I charged it directly to battery (by pass bms) with lipo charger, then bms turned back on, and charged fine again with its own charger. Maybe bms bad? How can i avoid bms from shut down, one way to go is charging it at 32v, and avoid bms shut down. I'm planing to sell it back, and don't won't problem with the seller later...
