medusa569
Using the original battery cells from EZee the cells seem to be LIMN. Since trouble when the battery kept shutting down for unknown reason I am trying using my battery BMSless. I tried for the first time to use a hobby charger ( Reaktor 1000w 30A) and a psu as power source. The psu is putting out 12.3 v. I powered on both appliances and after about 2 minutes I turned off the charger. It didn't seem to be acting like it did before during a trial run when first got it. This was my first time hooking up a battery to it...to be safe i started by charging only one pack of 20V I didn't get to even start programming it for charge before I noticed an acrid odor and shut it off. It was connected via a parallel charging board. After opening up the Reaktor I noticed a burned resistor..fried crisp critters but the small seemed to be coming from the coil area.
Any ideas of what could have fried the resistor and really heat up the coil ? I'm a first timer with this venue. I'm also trying to get a parts list for this item.....I don't know if I should count on the manufacturer for this. They didn't seem to know anything about the product when I "chatted" today.
