krik said:Hello folks,
there is mention of speeds of 15 & 20mph for this kind of drive - what happens when you are going down hill 30+mph and the drive is still engaged?
Does something get fried or it just not pull any amps?!
My friction drive tops out at around 28-30 mph so I've had to think about that exact issue.
Most people using friction drive on here are using some kind of arm or sliding mechanism so when the throttle is off the roller (or motor in some cases) is off of the tire or almost off the tire.
My sliding setup is always a bit engaged so I use a roller that has a one way bearing inside so it freewheels when not being used.
All that being said, I have my roller a little too far back on my bike so I sometimes spin the motor when I don't want to. I use a Castle Creation hv85 and I haven't had any issues with that. I have heard that the newer Castle esc's don't like it as much and will pop. So it seems it just depends on the controller.
I assume it wouldn't be a big problem if you used a ebike controller. Most of us are using an RC esc with our setups.
