I know this is an old thread, but did anybody ever find something out about the pinout and communication on the Bosch eco system?
For me it is interesting to reuse the Bosch e-bike without the battery as well as reusing the battery itself in different applications.
I know there are easiers systems to work with, as said on this topic, however, there are plenty of Bosch bikes around and so there batteries. So this is about reusing all of that.
I guess the battery is 10s NMC given the 18650 cells and 36v nominal voltage.
Apparently charging is pretty easy, as you have to apply 5volts to one of the pins, and after that you can charge. So it is fairly easy to charge it with something else, and you can also decide not to charge it to 100% with a different voltage (although we don't know the balancing threshold voltage)
But drawing power needs to communication and that seems to be CAN bus. I wasn't able to find if anybody already managed to check this out and replicate this. Perhaps I am using the wrong search terms, or nobody did this yet.
