johnrobholmes said:
How would a top balancing approach minimize usable capacity? It should do the opposite by ensuring that all cells are at the same SOC at the "top", giving maximal capacity for all cells.
The lowest capacity cells reach higher voltage first, so if you drain that extra charge off then they have less energy stored and will trip the cell low voltage cutoff sooner than it would have without balancing. It brings your pack down to what is stored in your worst cell group. I realize that's looking only at capacity, not IR, which would have the opposite effect by giving more of the charge input up to heat instead of energy stored. I view top balancing as a fairly crude approach, not an optimum. There must be some variability in cells and the voltage at full charge is not identical for all cells, so I don't agree that all will have max SOC at the same voltage. If it was in fact the maximum, then there wouldn't be anything to bleed off to help the others catch up.
For those running their packs at 90% DOD or more on a regular basis I don't doubt that an active BMS and balance charging is mandatory, but with conservative charge/discharge I'm not so sure. I look at running your tank low as something to avoid just like in a car, and until BMS's are closer to absolutely reliable and are a lot cheaper in relation to the batteries they're supposed to protect, then I think it makes more sense to spend that $ on more capacity given the nature of my use. I realize it's not for everyone, and maybe I'll be singing a different tune once I have cells nearing the end of their useful life and my loose approach isn't enough. In the meantime, my only dead lithium cells were killed by the systems intended to protect them.
John
