Chalo
100 TW
nutspecial said:It was def bent. If bearings are not destroyed and everything is tight but your pedals aren't on the same plane anymore then you either have bent pedals, cranks, or spindle.
Do I understand correctly that you formed your own square taper on the spindle end? If so, it could easily allow some ball-and-socket type movement because the fit is no longer conformal. That's my guess as to what happened.
