RoadWrinkle
Now that I am using my new Motiv eCruiser with much satisfaction (it is a hill climbing machine), the e-biking hook has been set well and I now want to build something else for flatter, longer rides and more top end speed. I want to go with a 1000w rear mount DD hub motor, and a 48v 10-12 Ah LifePO4 battery mounted in triangle bag, and a good controller mounted under the downtube. I also like the new Bafang 750w 48v 25A crank drive systems incorporated into the BB, a very clean looking system. I originally created this thread to decide which donor to buy.I bought the Specialized Rockhopper 29er Comp
Now interested in advice on the e-components, a front hubmotor would be the easiest in terms of install, but then I would have an unmatched wheel on the front and perhaps issues with the Rockshock (TA's, etc.) Rear mount hubmotor means no 10-speed rear cassette and again mismatched wheels. I Contacted Holmes Hobbie re sending the OEM wheel for hub motor lace/install (received no response after three days). Midmount would solve the above issues but I would lose the 3-speed front derailleur completely and Bafang system is a 68mm BB design, where I have a 73 mm BB on the Rockhopper, so 5mm spacing and chain line offset necessary.
Specs for Rockhopper:
FRAME: Specialized A1 Premium Aluminum, Trail 29er Geometry, fully butted w/ tapered headtube, forged dropouts, replaceable alloy derailleur hanger SWAT REAR SHOCK
FORK: RockShox XC28 29, TurnKey damping w/ lockout, coil spring, 1-1/8" alloy steerer, 28mm stanchion, preload and rebound adj., S: 80mm, Others: 100mm travel HEADSET1-1/8" w/ lower bearing reducer, Campy style, integrated full cartridge bearings
STEM: Specialized 3D forged alloy, 4-bolt clamp, 6-degree rise, 31.8mm
FRONT BRAKE: Tektro Draco 2, hydraulic disc, dual piston, 180mm rotor
REAR BRAKE: Tektro Draco 2, hydraulic disc, dual piston, 160mm rotor
FRONT DERAILLEUR:SRAM X5, 10-speed 2X10, 34.9mm clamp
REAR DERAILLEUR: SRAM X5, 10-speed, long cage
CASSETTE: Sunrace, 10-speed, 11-36
RIMS: RH Disc 29", alloy double-wall, 26mm, pin joint, 32h
FRONT HUB: Specialized disc, alloy, Hi Lo flange, RCC ball bearing system, steel axle, QR, 32h
REAR HUB: Specialized disc, alloy, Hi Lo flange, RCC ball bearing system, steel axle, steel cassette body, QR, 32h
SPOKES: Stainless, 14g (2.0mm)
TIRES: Specialized Ground Control Sport, 29x2.1", wire bead, 60TPIView attachment 2
