Eastwood
- Joined
- Jan 13, 2021
- Messages
- 1,480
E-HP said:Eastwood said:Well this hill is a lot steeper than my iPhone displays. It’s impossible to walk up this hill I’ve tried even with holding the ground. With my 5.5 T winding it would not make it up this hill I could only get about halfway. Then with this 6T it powers right up it no problem. I tried this hill when I was using the MXUS 3K 5T and failed. I guess so my point is without the proper winding a hub motor off road is no Bueno. With the right winding and mods a hub motor does well off road. By the way I had the controller set at around 8 kW going up that hill. I wasn’t quite at full throttle as I try to keep the wheel spin to a minimum with electric.
I should have recorded the $600 hill climb as that hill is an absolute monster. I pretty much ride on the back wheel going up the hill because it’s so steep lol. I plan on riding today and I’ll try to record the famous $600 hill climb lol
Do the hill at 5mph when you take the video, no faster, and you've proven your point. You can go straight, or zig zag up, your choice.
OK I’ll test it today and try to keep the speed under 5 mph. I’m about to head toward my local Enduro trail soon so I’ll post a video later. I just added F/F and hubsinks to the motor this morning so hopefully it’ll run cooler today 8)
