bowlofsalad said:
Stopping power is a concern for all who have lots of momentum. Amberwolf suggested kool stop to myself for roller brakes.
For *rim* brakes, not roller brakes.
circuit said:
So probably the only brake that can lock up the front wheel (on dry asphalt) while operating with one finger, is hydraulic disc brake? I'd really like them to lock the wheel if I decided to. I'm not a novice cyclist and don't like to use all my strength with full palm to come into rapid stop...
I can lockup CrazyBike2's front wheel with two (weak and hurty) fingers (probably could use one on a really good day for me, and anybody normal could do it with one), using just rim brakes.
26" wheel, rim off I think it was a Mongoose Basher (junk bike), Avid single-digit 5 arms, I forget what pads (might still be the Avid pads? I forget if they already wore out). Junk cable off some other bike, with two housings in series so it's a bit squishy, and ATM I think it's a cheap ebike ebrake lever, either that or an older Shimano type--I swapped it out at some point for some reason I can't remember, and I forget which was last on there.
Regular pavement, 300lbs of bike and rider, no rear brake, can do it even with another couple hundred pounds of dog food on the trailer too. Max speed is 20MPH, from there I have to apply just enough brake so I slow gradually so I don't lockup and skid isntead of actually stopping....
So no, hydraulic or expensive is not needed. Might be better under some conditions, I guess.
Sorry I don't have any experience with roller or drum brakes.
Some experience with "coaster brakes" like the one in the Sachs 3speed IGH presently on my trike (brake is not used there, though); they're ok, but I don't think they'd stop CrazyBike2 very well--a normal bike, probably. But would have to be kludged to use on a front wheel.
