justlooking said:
the bike is just a cheap one ,, and the cables are the spiral type ..there is no glace on the disks. i have only done about 50 miles on the bike since new
did they work better when new? If not, it could be adjustments or simply not being very good brakes (pads, or levers, or cables, or housings, or calipers themselves, or rotors, or a combination of the above).
I have tried a couple of the cheap Chinese brakes that are typical on cheap bicycles (BSOs as Chalo says), including YUS and Promax, and neither is worth the powder to blow them up.
On my heavy CrazyBike2, when i had a regular 26" wheel on the front, I had disc and rim brakes, and the rim brakes worked better by far (and are all I have on there now). the rim brake will lock up the wheel and cause the bike to skid, if I slam it on, or I can modulate it anyway I like for slowing down normally. The disc brake (either brand, or another one I can't recall the name of) did a nice job of heating up the disc itself but it didn't do a lot to slow me down, and certainly wouldn't lock up the wheel. It was also difficult to keep them aligned, and I ended up with pad rub fairly often, squeaking or squealing after every few uses even when not engaged (because I had to adjust the pads very close to the rotor to get any real braking power, regardless of housing, cable, or lever used).
I'm sure if I had tried *good* disc brakes (both caliper and rotor) then they would actually have worked as intended, but the cheap ones didn't, for me.
