John in CR
100 TW
Like I said before poor cells aren't worth fooling with. Don't you attribute value to your own time?
Entertainment is worth lots in my book. Remember my mbike from 2007? Took a BAD SLA with a dead/shorted cell and put it into a boost circuit. Didn't you and others tell me i was wasting my time? That was so much fun, adding 5 mph to my mbike, and watching guys like you eat crow.So you failed to make dubious cells workJohn in CR said:Like I said before poor cells aren't worth fooling with. Don't you attribute value to your own time?
Thanks for the Q.cassschr1 said:Ok I'm asking :lol:
yakyuyuyak said:Sorry Matt, I've been busy doing you know what. I'm almost done charging all batteries.
Yeah, that is the Achilles heel of those charging boards IMHO, they are rated to charge to 4.11 to 4.21. And in my experience that's what they do, highest I get from a bank of 16 of them is 4.19, lowest is about 4.12, most are at 4.15-4.17. They have a resistor you can change to adjust current rate, they come at 1 amp stock. I wish they had something similar for max voltage.
But for this purpose, I'm ok with what they do, can't have everything. No muss, no fuss, when the light says it's done it is. Many reviews of them on the web, they do an excellent job except for that small annoyance. CC, CV, even very slow buildup for undervolted cells (like you're doing?)
No reverse polarity protection, if you stick the battery in backwards the chip smokes instantly. Have smoked 4 of them in the last couple of weeks. But it's pretty rare to find chargers with reverse protection. Buy a few extra.
I've been using the original bank of 4 for about a year for other li-ion stuff I was doing, great. I just buy the $1.50 4 slot 18650 battery holders, they are touchy to work with but do the job. You have to remove the (must be like 28 ga.) silly wires that come with them and attach something more substantial, I use 18 or 22 ga. The rivets in the plastic are very sensitive to heat so you gotta be fast. Oh yeah, and then those holders are designed to series the batteries, so you have to chop the connections that do that, to make each slot independent.
here are reports in the es archives that confirm konions self balance
