riktit
10 µW
- Joined
- Mar 24, 2017
- Messages
- 5
Hi there, I have two 10s packs that I bought used. They are lithium ion. You may check out more details from Molicel here: http://www.wamtechnik.com/files/specs/642.pdf
The packs are 10s4p. There are two 5s balance connectors coming off of each pack. When I measured the voltage across the cells, I found that one parallel group on each pack is reading at .1 V The overall voltage of each pack is 37 volts, and the rest of the cells are within .5V of eachother.
I have an iCharger 1010B+ that I plan to attempt a revival with. I would like to know if anyone can offer advice on what to do/not to do during my attempt. I would also like to know what I can do if the cells are not recoverable, and how it will affect the rest of the pack if I don't rebuild the pack without the (possibly) dead cells.
Thank you.
Thank you.
