broken controller, short on bank of mosfets
uk
i have recently purchaced a 500w kt controller for my trike,
i set out on a journey and the bike started to missbehave, it would set off at full speed then lose power and go slower,
if i turned the bike off and on again it would set off at full speed again only to quickly drop down to a reduced speed again till eventually it just cut out all together and the wheel locked momentarily and then it wouldnt switch back on.
i got home with it and looked at the controller and the power cable at the xt60 connector had burned off like a fuse, so i tested the controller end and this was shorted so i opened the controller to inspect it but could see nothing burned so i tested the mosfets with a multi meter to find the middle bank of 3 mosfets were all showing shorts accross all pins, the other 6 were fine,
i have contacted the supplier on aliexpress and he recons its 1 of 2 problems, 1 bad wiring, which is bollocks and 2 the motor is too powerfull for the controller, which is also bollocks, it is a 500w bafang hub and the controller is 48v 11a/22a max, the one that came on the bike is 48v 9a/18a max and is working again (as my problem was just the julet 4 into 1 cable and not the controller as id thought)
so my trike is working again with the original controller and display, but this is besides the point, i wrote to him and said this in not so many words but he is now ignoring me so i have decided im going to attempt a repair myself and change out the 3 shorting mosfets.
so my question is
1) if i cut out the bank of shorting mosfets and test the power line that the short is gone once the mosfets are removed can i power on the controller and test if it works (ie should it work (either power up and display and/or work as normal at a reduced current))
or 2) should i not attempt to power it on until the mosfets are replaced?
all info much appreciated tia
If you remove the shorted parts you should be able to spin the motor maybe with a little help to get it started. I would not attempt actual riding or any kind of load on the motor. Depending on the level of sophistication in the controller, it may give a fault code from the missing bank of FETs.
