Hello All,
My Ebike 36V 250w rear hub motor suddenly stopped working. Initial symptoms are no pedal assist or throttle, no error on the M5 display, I did some troubleshooting and found that walk mode of the Ebike works, I also checked when I press the power button [M] and during this press the throttle the motor spins the rear wheel.
i checked that 5V are going to throttle and if i plug it to the multimeter, i can see variable current when pressing throttle (it’s thumb throttle) which indicate good signal, i checked that PAS green light flashes when turning the crank, M5 screen is set to electric drive mode And it doesn't seems to be an issue with P9, P10 settings of M5 display.
When i hooked multi meter to ground and one of the phase wire coming out of the controller, i can see it’s giving good DC volt not sufficient to drive the motor, however the moment i press the throttle the voltage turn to under 2 volt AC current ( i am using auto sensing multimeter). All the cables are tightly connected and none of the cable internally on the controller board is disconnected/broken. I also changed M5 Display with another one and observed the same behaviour. I have checked another e-bike where when i press throttle and connect multimeter to motor phase wire and ground, i get decent DC current.
Why the current will go into AC mode?
It looks like a controller issue however when i tested the MOSFETs(6) of them they are not shorting with -ve or +ve. Any suggestions what i can look further?
Regards, Tipu
Regards, Tipu
