well, you got huge balls and luck on your side !
balls because you continue to pull the trigger when other stops and that's insane because its self empowerment and engagement. huge respect !
luck because we are riding RC stuff on a longboard, any electronical or mechanical issue (not from the trucks or the native longboard which is made for high speed), but for the added component which can be altered because non stop vibrations due to the road could send you to the closest hospital in a second.
honestly, I would call it insane.
for the protective gear, and after my first fall at 25mph due to electronics (either ESC or nunchuck, but it looked like a "top" or a signal failure), I went for the following gear which is stealthy and make you looks cool... and a bit bodybuilded.
- Troy Lee full BMX protection
- TSG Padded protective short
- Triple Eight (non full face because this will cause me problems while riding in Paris.... less stealthy for everyone) helmet - if only I could go for a ruroc rx1 helmet !
- gform knee protection pads
that's it ! goes perfectly under classic clothes and really light/respirant materials.
