beetbocks said:
Hi
This motor will fit my new motor brackets with slots but the kv is very high and my kit (at the moment) is specifically designed for 170KV motor/15t motor pulley and 30T hub drive and the 265mm belt that comes with the kit..To use a higher KV motor the motor pulley and hub pulley need to be changed.. and then the belt will be the wrong length. My next project is going to us our 50mm 270KV motor and i will be developing a universal Hub drive so you can change the pulley wheel I will then offer the full kit for this.. you could just buy the same 63mm 170KV motors from Bruno that i use and it will work fine then
NEW motor Brackets - 2 sizes:
I can ship to Korea ,please use the US/Canada shipping for this..
I'm so glad that you can ship directly to Korea!! that will save be some money on shipping and taxes
Anyways, the problem is that i've already bought those 270kv motors and all other electronics.
I've done some calculations and it seems that 270kv motor will work fine with 2:1 ratio gears and 90mm Flywheels (Running on 6S battery)
kv/v = 270
voltage = 22.2 (6S)
Motor RPM = 5994
Efficiency = 70% (i've been told it's safe to assume 70% efficiency on the motors when loaded)
Motor RPM = 4196
Wheel RPM (2:1 gear ratio) = 4196 / 2 = 2098
Wheel Circumference = Pi * 90mm = 282.7mm
Which brings max speed to 36km/h (a little slower than expected)
Can you please check these calculations to see if i'm doing this right?
And now, how can i order the new motor brackets that will fit my motors?
do i just leave instructions on the paypal order page?
I also need customs invoice to show $80 so that they don't charge me import taxes.
And it will also be great if you have 15T motor pulley with 8mm bore
