jacobbloy said:Hey Guys I need to get some quick moneyknow for another knee reconstruction, so I'm selling my boards in parts or full, the only problem is I don't have the trucks any more, I still have the mounts but I sold the trucks.
So for $400 NEG you get a preassembled deck only missing trucks,
You get:
Abec 11 wheels worth $60
Twin ESC 120A worth $200
2 motors worth $50 each
Battery worth $50
BMS and charger worth $50
Alien full kit with custom rey mounts worth $400
Deck worth $100
Alien cases $30
RC controller $20
Total savings $600
If you don't want to use the rey mounts you can buy just the caliber mounts and a set of trucks or I can send you a set of holey trucks and mount included in the price
Thanks guys
simonjook said:Though in the interim - the motors have a lot of "slop" in them. The drive shaft has well over 1mm of axial free play and is actually only stopped by the fact the pulley makes contact so I am yet to see how far it actually moves. Is this normal? usually if I get this much play I'd think I'd killed a bearing but there there is no sideways play so I don't think this is the case. I'll get the pulleys off when I get home but working away at the moment so don't have a full set of tools so can't check just how much play there is.
They are the Alien motors with the red bell ends - does anyone else find this?
torqueboards said:Possibly, a firmware issue? The brakes are decent and I'm running them at 70% but have set them at 30% and they were still fine then. At faster speeds the better it stops to a certain extend - 15 mph requires a specific amount of space for stopping distance. It's best going about 5-10mph and stopping versus going 1mph and stopping.
beetbocks said:tap the output end of the motor shaft..so you push the c-clip tight up against the motor bearing.. then re-tighten grub screw.. they do tend to get loose after the first run then once you tighten it then, it tends to stay tight
