LED lighting kits now available-get them while stocks last!!!
http://www.aliendrivesystems.com/led-lighting-kitnew.html
beetbocks said:the problem would then be applying pressure with the belt on..as it is now you can roll the belt on the wheel with sufficient force.. the other option i was considering was a bolt in the back of the mount and screw this in to tighten..?rf said:beetbocks said:Great stuff Jacob..
Just a quick update on the Caliber mounts..I was just about to get a batch manufactured when i realised that not all the existing Alien brackets will fit the caliber mount. So i have to redesign the bracket and prove the design..so hopefully in the next couple of weeks..sorry for the delay but it will be better for everyone in the long run
Cool.
Not sure if this applies to the Caliber mounts. But on the Holey mounts, if it were possible to insert the four bolts in the opposite direction (heads facing in), you could adjust the drive belt without removing the wheel -- and with the belt actually on. Just a thought.
Richard
beetbocks said:LED lighting kits now available-get them while stocks last!!!
jfeola said:Anyone think of using any of the other ESC's? Just curious about whether any of the airplane or heli ESCs would work or if you forsee any problems with that. Maybe even a boat ESC like the seaking (although that seems to be water cooled).
Great stuff on this forum. Thinking of building me one.
Justin
I have a couple different plane ESCs that were quite cheap. A Mystery CLOUD-200a I got on Ebay for $36. Supposedly capable of 200 amps with 6S Lipo. And an HK SS-90/100 (Hobbyking.com, $25), that's spec'd at 100 amps with 7S Lipo. They work okay, but the brakes are not-so-good. Airplane ESC brakes are very simple -- designed to stop the prop abruptly. And send a skateboard rider flying off the front in a hurry.jfeola said:Anyone think of using any of the other ESC's? Just curious about whether any of the airplane or heli ESCs would work or if you forsee any problems with that. Maybe even a boat ESC like the seaking (although that seems to be water cooled).
Justin
rf said:The only substantial difference between these units is the software. They're each just a collection of high power MOSFET transistors controlled by a small, fast, microprocessor. The software makes it all work, gives them their features.
simonjook said:rf said:The only substantial difference between these units is the software. They're each just a collection of high power MOSFET transistors controlled by a small, fast, microprocessor. The software makes it all work, gives them their features.
As you say they are only designed to stop a prop spinning abruptly. This change in the mechanics for car or skateboard braking requires more than a just a change in software but a way to deal with all the extra energy that needs to be dissipated when braking a large mass for a longer period of time - It's more than just a software issue. Car ESCs typically have more heatsinking and often active cooling (a fan) to deal with heat generated when dumping energy during the longer braking process. Plane ESCs (when reprogrammed) generally go pop on long braking if they aren't modified. You can't escape the first law of thermodynamics![]()
old man said:Hi,
why not add this kind of brake system ?
http://www.longboardshop.de/shop/product_info.php?cPath=62_213&products_id=2158
It willsave ot lot of electrical energy , ESC heat , belt breaking or so .... I've got one of this Pogo brake and I sometime use it to film our longskate DH crew, then it's easy to control speed without thinking of your hands , and you may focus on other riders : it works very well ! With motor(s) installed at the rear , and battery a little forward, it could be possible ?
I've been biting my tongue, but Pogo is so not cool. It's almost childish. Do I get a cartoon boat anchor to throw out too? Using the widely varying road surface as the friction component for your brakes is just plain wrong!torqueboards said:How would you implement the brakeboard with regular trucks? Pogo is cool but wish it was much smaller.
I agree, it's all too expensive... That's why I like the pogo brake. Experienced skaters might think it's not done, but I don't care about this if I can prolong the life of my components.rf said:I think one motor is sufficient for powering the board. Mechanical brakes on the two front wheels seem like a good choice for descending hills safely. The simplicity and reliability afforded seem likely to easily surpass motor-driven braking in almost every way.
I am a little put off by the current cost of mechanical brakes. And by the need to mix trucks.
