Glen
10 µW
Hey guys,
I made a brushless etek pocket bike some time ago with the intention of racing it against the gassers. i did end up finishing it but it had a few problems relating to gearing and just general build quality!
but the real death of it was the terrible performance.
the specs where
-Brushless etek
-Sevcon millipak controller
-80x cp2400 nicad cells so 24v at about 9ah or so
-total weight of the entire setup was about 70kg myself included.
now the top speed was great once you get it wound up (it didnt have much gearing on its side as it was geared to about 150km/h) but the low speed performance was terrible. to the degree it would barely move and just shudder violently. i thought a factor of the gearing.. so i changed the gearing for a top speed of about 50km/h and the accelleration was still quite terrible. if you slowly apply throttle it will take off just fine BUT if you crack it open from closed it will just shudder violently like taking off from a dead stop in your car while in 4th gear.
a good friend of mine also put the same setup (with 36v SLA batteries) into a 250cc road bike and experienced the same thing with very mediocre performance.
im just dont believe that a motor reported to be at least 15hp can perform so terribly. on the calibrator the current at take off is almost 300 amps so it *SEEMS* to get full current but what its doing with it i know not...
has anyone else had problems with the sevcon millpak? personally i think its the controller screwing the works up and i will be getting rid of it none the less probably for a kelly controller as i cant stand the vast looms of wiring you need to run the sevcon and its pretty large for a pocket bike. just a bit dissappointing to spend $800 on a setup that i could ride faster then on a pushbike
ive seen plenty of vids of normal eteks and they seem to go like i want.
is there some specific setting in the controller maybe ive elluded? ive changed everything basically one at a time from stock settings and everything in between to no real avail..
heres some piccies anyway to exemplify dodgyness of the prototype!
heres some specs on the new version -
- 36v A123 cells (probably 9ah) with integrated charge ports to get it charged nice and quick
- Kellycontroller
- much smaller chain drive and gearing to 100km/h
- custom alloy frame
heres the new frame - all 100% made from CNC machined aluminium. was gunna be a new gasser but the EV takes priority!! :lol:
look foward to being a member of the forum too. thanks guys!
the specs where
-Brushless etek
- Kellycontroller
