Thanks Ian for the quick replies and enlightenment. I am going to order the controller you recommended.As far as the sprockets mentioned by other post we are already maxed out with that 90T on rear 10T front. Will be good to upgrade to 8mm chain and sprockets as well.Was wondering if you are familiar with Kuberg electric cycles. Neighbor kid got one for xmas. Absolutely beastly torque from this bike. He has the trail-e 36 volt model. It has wheel spinning dirt slinging torque and seems to go forever on a full charge. The batteries are 3x 12v SLA 15ah .Motor is small and obviously brushless says its rated at 3kw the chain and sprockets are 8mm. The spec sheet says the controller is rated at 40 amps. Have not got a good look at the controller to see any info on it it is pretty small (cigarette pack). Other than the frame its basically high end mountain bike components.So the magic is all in the motor and controller obviously.My sons over volted (48v) razor would beat it on a long drag race but the Kuberg is crazy fast off the line and incredibly torqy in the woods which is where they ride.Lots of wheel spin and easy to lift the front end up.It is very good for off road motorcycle training without disturbing the neighbors.What are your thoughts on what they have put together(electrically speaking). We are not going spend 2000.00 dollars on one but I am up for the challenge of hopping up the razor on a reasonable budget for the fun of it.My guess is they are doing a bit of what you suggested with higher volt motor being run with less voltage and well designed controller?????? I would like to know what you think is going on there. Here are few links to bike. Thanks for your input on this.
http://www.kuberg.com/young-rider.html#/triale
https://www.amazon.com/Kuberg-2016-Trial-Electric-Bike/dp/B01BMO2WRQ/ref=sr_1_3?ie=UTF8&qid=1484942342&sr=8-3&keywords=kuberg
