Budget high power 18650s - EVE 20P or Samsung 20R?
ljbred08
🔋 Established
Tampa, FL
I am looking to build some starter batteries (72V) for myself and a friend on a budget. The cheapest options I have found right now for high power output are the EVE 20P overstock from Battery Hookup at $0.79 per cell (EVE ICR18650 20P 3.6V 2000mAh 30A High Rate 18650 Li-ion Cells - Overstock!) and the EV West Samsung 20R modules at $0.50 per cell (Samsung INR 13S 54 Volt Lithium Ion Battery 20R Scooter and eBike Battery Modules, discussed in EV West Too Good to be True? 50¢ per cell, new and Great deal on battery pack).
The reason for not getting some newer, higher capacity cells is that this is the cheapest way I could find to get adequate discharge current. Target pack output is about 80A discharge for a solid 5kw. With the common 21700's that have about 2C discharge, I would have to make a 40AH pack to get enough discharge current. I don't need the size or the cost of a 40AH pack.
Question: Is there a good reason to get the EVE 20P's over the Samsung 20R's given that the EVEs are more expensive? For the same price, I can get a lot more of the Samsung, and the specs are practically the same.
The main difference I can think of, besides pack teardown annoyance with the Samsungs, is that the Samsung packs are probably much older. However, I don't know how much of an impact this has on the final pack.
Of course, if anyone knows of a comparable deal on HIGH CURRENT 21700s, I'd be glad to hear it! The problem has been I need at least 4C discharge.
(FYI, it is true that I have been very interested in pouch/prismatics such as those from Greentec because of the value; however, for maximum flexibility (pack size), simplicity, and reliability, plus the fact that I need to get a spot welder anyway for something else, I've decided I should probably just go with the tried-and-tested cylindrical cell method.)
I would go with the EVE cells from Battery Hookup. You know they're new, and you can build the pack however you need to. The Samsungs would need to come apart, unless you can use them as modules. And you have no idea on the age.
And I've had many more positive experiences with Battery Hookup than with EV West. Back when I lived in San Diego I visited the EV West office to purchase a Tesla battery module. They literally had some on the shelf and I kept getting the runaround about buying a cheaper one with blown fusible links for not much less than a fully functional one. Suffice it to say, I took my money elsewhere.
