Hi folks,
thanks for lots of useful resource over here.
This is my first post so plese be patient with me for some time.
I have done road, mountain XC and DH races before, so I have been using pretty much all kinds of bicycles over the past 25 years.
Recently I picked a Kona Ute 700c wheeled cargo bike which I love so much for its shopping and commuting ability, and still being a piece of art itself, turning a lot of heads (including mine). I can easily get it to 30kph on windless straights and climbing is also no big issue, you just feel the extra weight. The frame gets some flex from strong pedaling under high rear load (more than 20kg), but I can cope, being 75kg myself.
PIC: MY CUTE KONA UTE (note I added chrome mudguards, lighting, bell, horn etc...)
As you see the bike has a lot of space for battery / controller and still carries a lot of goods.
To be able to do longer shopping and commuting routes (40-50km), I decided to get a LiFePo4 battery and a decent hub motor, preferrably between 250 and 500W. I want to stay away from chain drive for the extra noise it produces and the aesthetics, of course. I want to keep the build as classic as possible, no nerdy visible parts if possible.
My aim is to keep pedaling as much % of saddle time as possible. The terrain is not very hilly over here, but there are some sustained 1-2km climbs, if not too steep (max. 8%). There are also some short 12%+ climbs, but I am ready to help extensively during these. My idea is, if I can master these steep climbs at 9kph, so adding a motor should help me get to 15-18kph, which is the minimum speed that I require the motor to run at. However, being able to run 30kph with my human power means that I'd like the hub to be able to get to 40kph comfortably with my pedal assistance = 48-50kph with no load w/ 700c wheels.
After some forum and market research, I decided to buy either a Bafang or Cute 350W/36V motor from BMSBattery.com (good seller?) and run it at 48V. Thus I don't have to use full throttle/amps at high 30kph's w/ easy pedaling, and power will be high enough with a 25A controller on those steep climbs at 15-18kph with moderate pedaling + WOT.
I'm probably going to order 2 hubs plus some replacement nylon gears, in case anything goes bad and China happens to be too far from by bike that particular day.
First question: Are my maths OK? I assume the hubs will do 50kph with no load and 700c wheel, and a 25A controller (delivered with the hub from BMSBattery)
Second: Are the hubs durable enough to withstand such V/A loads and last thousands of kms? I believe so, though the Cute's don't have any track record yet.
Third: Front fork is a Kona P2 steel. It could bear a lot of abuse and run these motors safely, keeping my bike better balanced (much load in the rear already), but still I prefer the rear motor for traction and safety reasons. Is the rear Alumimium dropout OK for the 350W motor?
Fourth: As already mentioned, I carry 30-40kg load in the back from time to time. Is the Bafang / Cute axle going to be fine under this load?
Fifth: There is a known issue with rear Bafangs where the threaded cassette flange would separate from the hub under high pedaling loads. Is there anything I can do to avoid this failure? I guess it is vital to keep the chain as close to the hub as possible, thus lowering the lateral torque.
Many thanks to all replies!
