Felixaustria said:
13s8p alone can not give 100km specially when attached with a 15kg trailer.
Many users here (including myself) could ride not just 100 km, but 200 km with your 13s8p, not at 40 km/h, but at 25 km/h, and with some pedalling. This is feasable with a normal ebike and some training.
Let us return to your goal:
You want to make 300-400 km per day at 40 km/h without pedaling with an electric bicycle.
Aside from other prerequirements for 400 km/day on a bicycle we can regard your question as a technical issue and try to solve it.
Energy:
You would need about 10 - 15 kWhrs of energy.
If we assume a specific energy of 200Wh/kg for Lithium Ion cells, we would need about 60 kg of battery cells.
Let us add 20 kg for a rigid case, and calculate about 80 kg for the battery.
Bicycle:
A cargo bike can carry that additional weight. A tandem bike could do it as well. Neither of them is build for continous 40 km/h. Some parts have to be upgraded, you need spare parts and the skill to repair your bike on the road
Charging:
When you arrive at your destination with a single charge, you still have to charge your batteries for the next day. Let us assume, that you have 10 hrs time. Then you need about 1,5 kW of charging power. Divide your monster battery into 5 partitions and you can use 5 pcs. of a 300W charger like Meanwell HLG320. the 5 sub packs should be indentic if you want convenience
Other prerequirements:
the fitness to sit on a bike for +10 hrs a day, good navigation skills, bicycle mechanic skills, a budget of 10k USD for reliable quality of all components
