izeman
1 GW
i know there are some threads about lipo fire, some about storage tips etc...
i'm looking for a solution to store quite a lot of lipo in my basement. i know this should ideally be stored outside in a fire place. but climate here doesn't permit that.
so i thought of ammunition boxes. you can get them used for $20 each here. the ones which are 30x15x18cm (12x6x7in) should hold 10 of those 6s 5000mAh HK lipos.
which definetely is WAY TOO MUCH
i think of something to hold 4 packs to
a) make the energy contained not too much
b) reduce the amount of smoke
c) reduce the amount of heat
d) last but not least reduce the money literally "burnt"
in case of an incident.
so what are your suggestions? can these boxes stand a lipo fire?
would it be better to add pressure release holes or to make them air tight?
