SafeDiscDancing
🚴♂️ Mega poster
- Joined
- Jan 3, 2022
- Messages
- 514
Quinc said:Any issues with heat? I would like to push them as hard as I can with a 150a controller and QS2000w motor. Would I be okay to store them in a water tight box, or do they need some air flow?
150a for an 8ah pouch cell?
That's roughy 160/8 = 20C.
I'm guessing "No" not a good idea. Maybe if you parallel two 8ah cells like over at Battery Hookup where they sell the hardware including the bolts and clamps you could pull off 10C... but no way it will survive 20C for long.
And if the temperature is below 50 degrees expect to have to ride them once just to get them up to full temperature and power. When cold the voltage drop is much higher so you feel like the battery is closer to empty despite being full.
For what you want I'd say something more like 20ah would be good... pouch cells around 30ah are the new "standardized sizing" for all future LG Chem pouch cells so I'd look for those.
Those are roughly 14" long, 4" wide, and about half an inch thick.
