Building a reduction gear techniques
Kiza
100 µW
London/Brighton, UK
Today I learned that sprockets do not weld well to mild steel...
I've got it holding for now, so I will see how long it lasts. I've added more tacks since the photo.
The plan is to put two thrust bearings on each side and put a bolt through the middle to bolt it to the frame.
My other attempt was to buy a roller sprocket from Aliexpress.
I was going to buy two and weld them together but only 1 came in the right chain spec. It was a long wait and being only seller of these I didn't know if I would get the right parts after another month wait so I decided to try the method above.
Does anyone have any other suggestions for cheap and easy reduction gear implementations?
First, what exactly is your project and needs? There may be some other solution we could help you work out, or a better / different way to do the one you're already doing.
That said, steel sprockets generally weld fine to mild steel...but if the steel has a coating (like if it's galvanized) it may have to be removed first. It may require higher current than you're using to get a deep enough weld, however.
I'm going for a 1:7ish gearing reduction for the QS 3kw mid drive. Trying to avoid putting an massive sprocket on the back wheel.
Interesting about the sprocket welding - maybe I need to tweak my welder settings but I think it should hold for now. I did take off the coating in the area before I tried welding it.
