auraslip
- Joined
- Mar 5, 2010
- Messages
- 3,535
Who has the most efficient ebike here in terms of Wh per mile? What's your setup?
I want to build an electric bicycle. As in, 23 mph top speed, and built to be pedaled. This will suit my commuting much better than my other 50 mph bike that will overheat or give me range anxiety if I'm not careful. Also, at stock power levels I'll have much less reliability issues!
I'm thinking a vintage steel road bike frame might be good platform or a newer $200 AL cross frame paired with a geared hub motor.
Lastly, I'd like to have the battery pack at less that 40v. Why? Because I want to build some of the components for the bike myself such as on board charger, DC/DC, and startup circuit. Above 40v the ICs to make these components are non-existent or very rare! Also, less packs in series are MUCH simpler to monitor. I'm stilling having nightmares about the 50 feet or so of 20awg wire I used to make the balance harness on my last bike.The perfect setup would be an 8s battery pack made from 4s hard case lipo bricks, but I'm not aware of anyone running their bikes on a voltage that low.
So I guess I'm asking: what sort of efficiency can I expect from a geared hub at lower voltages like 8s, 10s, and 12s?
