dogman dan
1 PW
Well, I'm not going to burning man myself. But I have wanted to do this since I got my first hub motor.
Still very much a work in progress, but that picture shows the point I'm at now. Two hubmotors, two large casters from Harbor Freight, a pair of steel frames to hold the motor and caster, and a wooden frame and deck that will have a couch attached to it.
One primary design consideration, is to get to something that could plausibly go to the playa, in a hatchback. Nothing longer than 5" except three or four 2x4's, which could be bought in the last town on the way to the party. The plywood deck can easily be done in 3'x4' sections, able to fit in the hatchback. NO need to haul a trailer to carry it to the burn.
Obviously a couch is harder to carry, but you can arrange for a camp mate to bring the couch, or even trade for use of a couch when you get there.
This setup will be ideal for use with two of the E-bikekit trike kits because they have reverse, and a low speed.
(shamless plug)
But I'm building mine for much more power and speed 0f course.
I have two of the old 9x7 motors laying around, and will be getting two new controllers with reverse on ebay. 48v 40 amps controllers. So I'm thinking close to a 30 mph couch, and hopefully some fairly quick take off.
It must have reverse, to do what I want in the first place. I want skid steering, one motor forward, the other in reverse, and spin till you puke. A search of motorized couch vids on you tube did not show any skid steer couches.
You will also notice as I get into the build details, that the two motor frames will easily adapt, to create a dual rear drive trike. But no pedals, since I built it for front motors. Still possible to change the frame for one rear motor though, and make it able to pedal.
