CA3: How to get 100% regen when tapping ebrake
maxmapper
Los angeles
I am trying to get my Cycle Analyst v3.1 to send 0V out on the throttle line when the ebrake is tapped. On my CA3 setup under SETUP EBRAKE I correctly see the lever animation move when I press and hold the ebrake lever. I have proportional regen off and I have the voltage set to 0.0V. However, on screen 12 (press left once after turning on CA3), when not pressing the throttle it always just shows the output voltage at whatever the minimum Output Throttle Setting is set to. So if I set the minimum to 0.99V, screen 12 will show 0.99V whether or not I tap the ebrake. I would have expected the voltage to drop to 0V when I tap the ebrake. If I set the minimum Output Throttle voltage to 0V, then screen 12 shows 0V when idle, and I correctly get regen braking at full power. However, this means regen braking is always on unless apply throttle. I only want regen braking on when the ebrakes are pressed. Maybe I'm missing a setting or misunderstanding something? Thanks in advance for any help!
