Bill Nye the science guy
- Joined
- Jan 22, 2013
- Messages
- 115
Good to see all my old ebike friends are still up to their old tricks.
I am building a new battery pack for my bigger frame and moving all the parts to the new frame. I was going to use lithium ion 15 ah pouch cells from bmsbattery.
I couldn't find the answer to this problem, lets say 2 60volt 15ah packs with 2 separate bms's feeding into one controller.
I remember hearing that this will make a kaboom because any unbalance will cause one battery to charge the other when load is low maybe over heating the bms?? could it be done with two diodes, one from each bms before they T ? would lose any regen that way.
or is there already a solution? would be 2p 16s Li-NiCoMn
Thanks
Thanks
