rick_p
⚡ Regular
Having a hub motor be incompatible with a controller goes against my limited knowledge about the technology, but I'm not sure what else would cause this behavior.
Here's the situation, I have a bike that was cobbled together using used parts, and it works just fine, I have well over a thousand miles on it, but I picked up another (used) rear wheel the same size as mine with the same 9-pin Juliet waterproof cable, and just wanted to test it to make sure it works and keep it around for a spare. So, I put it on my bike for the test, and the bike turned on just fine, the display reported no errors, but when I went for a test ride, the wheel only works using the throttle, it doesn't respond at all to PAS, and the speedometer is way off too. I put my old wheel back on and everything is fine, any ideas what might cause this strange behavior?
Thanks in advance.
Thanks in advance.
