Hi all,
I have recently built an ebike using parts from a generic MTX rim 3000W hub motor conversion kit
72v30ah 20 cell battery with an 80A JBD BMS
Fardriver ND72260 Mini12
3000W Hub motor wheel 27.5 inch
Wrist throttle
It seems to run completely fine when you lift the rear wheel, perform auto-learn, give it full throttle. I can see it spins up to 900 odd RPM with no stuttering or juddering at all.
However under load, the motor cuts out at around 450RPM or 30-32mph. The motor will not be operable until I come to a full stop and the controller detects it. At which point it will let me use it as normal again.
There are no errors or faults in the Fardriver App (I screen recorded and checked every frame), BMS does not get tripped (I have dropped the line current and phase amp current to 40A and 180A which led to the same result), no errors on the BMS either.
The only thing I see is it going from MTPA to Weak on the graph page, which suggests a field weakening issue. I've changed the weak character and response to loads of different combinations and nothing seems to affect it.
Temperatures and amp draw looks completely fine, I've separated the hall sensor cables (even twisted them to reduce any potential EMF interference), triple checked the phase cables and nothing seems to make any difference.
Set the ratios to both 100 percent and 0 percent, no difference there.
Does anyone have any advice?
Wrist throttle
