As you may know, all of those turnigy/cheap blue watt/volt meters (those that go up to 60v)
have 4 wires (red and black for load and red and black for source).
Is it possible to get all the readings correct if i connect only the Source side in the middle of my battery wires?
(scratch the wire insulations in the middle of the battery pack chord and solder the Source side of the watt meter).
Will it work? or do i have to connect both sides of the watt meter?
Roy.
Roy.
