Little-Acorn
- Joined
- Oct 15, 2009
- Messages
- 130
I've seen Headway 38120 LiFePO4 cells (10Ah) that have screw terminals, and other Headway 38120s that appear to have no terminals at all. I know that some cells have flat tabs spot-welded on. But I can't spot-weld!
Does anyone know if it's possible to solder some flat tabs directly onto these no-terminal Headway 38120s? Screw terminals are too tall for my applications.
If I use a large-capacity soldering iron that can heat up the metal quickly, solder the tab, and get off quickly so I can cool the solder connection, do you know if this can still damage the cell internals? I've tried soldering to NiMH cells, and ruined my share of cells doing it. Don't want to ruin these (expensive!) Headway LiFePO4s!
Anyone know if it's possible to solder directly to these cells? (or, if these cells can come with solder tabs already installed?)
