Can I use these balance wires to balance the pack with a buck converter? This balance board isPOS.
James340
Aguila Arizona USA
I thought charge series #1 with 4 volt series #2 with 8 volt ect.That is how the voltage measured on the connector.It is a series adding voltage with each additional series
Would recommend you get a BMS. with passive balance. Active balance is not needed for closely matched cells.
How far out of balance are your cells? balancing takes time even at 1.2A
But to answer your question in the title of the thread. No
later floyd
later floyd
Thanks for the help.
