Can two connected motors running on the same shaft be hooked up in parallel like this? http://imgur.com/a/XmLcb
I removed the shaft on my motor and going to add another motor to a longer shaft so both motors share the same shaft. http://imgur.com/a/a1hvC
Both motors will be mounted in a aluminum tube so they both spin the same. https://endless-sphere.com/forums/viewtopic.php?f=1&t=84255
I was going to use two vesc esc's but figured if the motors would work connected in parallel just use one esc.
