zombiess
Just thought about this. What happens if you parallel the phase wires of two identical controllers together with identical settings, same throttle (easy as hell to split a throttle to multi controllers). Would it work, why not? If they each had their own separate battery pack it would fix and shared ground issues would it not? Could they be run from a single pack?
Two or three 150V 18 FET controllers in parallel would be a nice packaging arrangement for a delta mode modded motor. 36 FET's. Not sure if these controllers use an external clock source, but if so it's not that difficult to build a single clock source to link the two into sync (done it with other micro controllers) if having PWM out of sync is much of an issue, if not, bonus. Two 150V 18 FET controllers each with their own 125V 10AH packs sure would pack a wallop and make for a fun ride and be pretty cost effective, 125V@120 battery amps/360 phase amps if it works. There will also be illegal speed runs on the highway if this is possible.
What kind of controllers are out there for 150-300VDC? I was thinking something that could burst around 200A. They seem to get pretty pricey at this range
yes I'm totally serious. I did just take a large amount of a prescription substance so I'm planning my own demise and kicking around some ideas. Setting a record is a happy thought right now. Should to sign off, getting double vision but feel awesome.
Will those on here with a fuller understanding of these controllers please step up and tell me what could go wrong and the challenges involved . This setup would probably go to Bonneville and use active cooling on the motor. I'd like to burst around 80+ KW into the motor I'm getting.
I know most people on this forum don't know me well, but this is the crazy shit I come up with when I start to think outside to dodecahedron. I'm too high on Carisoprodal (I'm such a lightweight due to never taking drugs before) at the moment to think of the failure mode if any (body diode cond. I've given up, frock money frock everything, I have some new goals and they involve ludicrous speed. Might as well use my high IQ for something beside looking at porn and pulling my pud.
