000001: PnP Event (DOWN), 17.11.2015 18:48:50.957 (1. Device: Porta di comunicazione (COM1)) The device has just been connected to the system.
000002: Create Request (DOWN), 17.11.2015 18:49:00.773 +9.815 (1. Device: Porta di comunicazione (COM1)) Process 0xc74 (Kelly Controller.exe) attempted to open the device
000003: Create Request (UP), 17.11.2015 18:49:00.788 +0.015 (1. Device: Porta di comunicazione (COM1)) Process 0xc74 (Kelly Controller.exe) create request status: 0x00000000
000004: I/O Request (DOWN), 17.11.2015 18:49:00.788 +0.0 (1. Device: Porta di comunicazione (COM1)) IOCTL_SERIAL_SET_QUEUE_SIZE: Set queue size
InSize=512
OutSize=512
000007: I/O Request (UP), 17.11.2015 18:49:00.788 +0.0 (1. Device: Porta di comunicazione (COM1)) IOCTL_SERIAL_GET_BAUD_RATE: Retrieve Baud Rate
Baud Rate=1200
000009: I/O Request (UP), 17.11.2015 18:49:00.788 +0.0 (1. Device: Porta di comunicazione (COM1)) IOCTL_SERIAL_GET_LINE_CONTROL: Retrieve line control
WordLength=7
StopBits=1 stop bit
Parity=No parity
000022: I/O Request (DOWN), 17.11.2015 18:49:00.788 +0.0 (1. Device: Porta di comunicazione (COM1)) IOCTL_SERIAL_SET_BAUD_RATE: Set baud rate
Baud Rate=19200
000024: I/O Request (DOWN), 17.11.2015 18:49:00.788 +0.0 (1. Device: Porta di comunicazione (COM1)) IOCTL_SERIAL_SET_RTS: Set RTS
000026: I/O Request (DOWN), 17.11.2015 18:49:00.788 +0.0 (1. Device: Porta di comunicazione (COM1)) IOCTL_SERIAL_SET_DTR: Set DTR
000028: I/O Request (DOWN), 17.11.2015 18:49:00.788 +0.0 (1. Device: Porta di comunicazione (COM1)) IOCTL_SERIAL_SET_LINE_CONTROL: Set line control
WordLength=8
StopBits=1 stop bit
Parity=No parity
