cwah
I previously purchased an ebile, but it's way too big (25kg) and too slow (only 33 kph max speed). I can't even carry it in public transport so it's time to change!
I'm planning to change it to a faster (40-50 kph) and lighter bike (less than 20kg). I'm now narrowed to 3 choices, but I can't decide. So I'm asking for your advice.
Choice n°1:
Brompton bike + Crystalite 209.
Pro:
- Best of the best for folding bike
- Easy to carry on public transport
- Can go to groceries with my bike folded
- Regen possible
Con:
- Direct drive so it's a bit heavy. Motor is 3.9kg + controller weight will add a total of 5 kg.
- No freewheel
- Efficiency is lower with direct drive
- Not that stealthy because of the big motor visible
=> Bike without battery would weight around 17 kg (12kg + 5 kg) with a max speed around 45 kph.
Choice n°2:
Dahon uno + friction drive (can buy the one from Kepler or Adrian)
Pro:
- Quite stealthy
- Very light (1-2 kg added max for the motor + controller)
- Freewheel
- Good efficiency
- Motor is cheap to replace
Con:
- Can't work under the rain and that's a big issue because I live in london and it's often wet.
- Still a beta product
- Need to have a minimum speed of 12 kph before I can start the motor
- Limited speed (around 45 kph max)
- Most noisy
=> Bike without battery would weight around 12 kg (10kg + 2 kg) with a max speed around 45 kph.
Choice 3:
Dahon uno (same bike) + geared drive (BMC, mac or Cellman?)
Pro:
- Freewheel
- Can have good acceleration on start
- Better efficiency
Con:
- No regen
- Noisy
- Difficult to repair if there is any problem
- May not be possible to go very fast
=> I don't know too much about geared motor, so I'm not sure which one would be the best one for my need.
I have now a big dilemma, my first choice was the friction drive for the weight but as I live in London it may not be appropriate when it's raining. So among these 3, what would be the best choice for a commuter looking for a light and fast bike?
Thanks guys
Choice n°1:
Pro:
- Regen possible
Con:
- No freewheel
Choice n°2:
Pro:
- Quite stealthy
- Freewheel
- Good efficiency
Con:
- Most noisy
Choice 3:
Pro:
- Freewheel
- Better efficiency
Con:
- No regen
- Noisy
Thanks guys
