johnnyz
Hey guys
I have built many packs this summer and wanted to share a huge failure I had and wanted some opinions.
After making the pack (24s 10p) I delivered it , the guy tested it and was great for about a minute and then stopped...
When I took it apart to see what had happened I saw the BMS blown apart. He admited that they were using a very high powered controller but was unsure of how many amps it was pulling. He did say the bike was able to spin the rear wheel and was "fast as hell".
Question:...The pack was made using Panasonic NCR18650PF cells, so 10 in parallel should handle 100 amps. However because the first build was too large I had to dis-assemble the pack and reconfigure to a taller type. While doing this with the BMS still attached the negative wire just touched one of the negative terminals of one of the cells and I got a huge short...I thought the BMS was damaged but finished the build and put it together. It accepted charge and stopped the charge when voltage got to about 99.3 volts, so I assumed the BMS was ok...then this happened...could this be the result of what I did or was this the result of too much amperage and a failure of the BMS to sense current and shut the power off??
