Doctorbass
After assembling many M1 cells, i had different experiences and results about succes to get a good battery pack.
Now, i need to find the REAL way to match cells. I am not sure about capacity matching and need to clarify that with your opinions.
First, i think there are at least 4 parameters to take in acount about cells matching:
-measured internal resistor
-measured capacity
-the age of the cell
-the past event that happened with the cell (over dis/char, reversed..)
Like you know, most of my M1 cells come from defect 36v battery pack so it's not difficult to get good and bad cells.
When i get the pack, i first measure each voltage from those to identify wich one have low voltage. I dont know what is the past of these pack, so it's the only way to get info about those.
I often get at least 2 or 3 bad cells out of 10 on each pack. I consider bad when voltage are under 2.5v and other are like 3.2-3.3V. I suppose that they could have go lower tham 2v because after it occure, the voltage usually rise a bit.
I am confused about something strange: the measured capacity of the "bad" cell is good most of the time !!? .. i measure around 2250mA. I see no capacity difference between bad and good cells
Now, if i decide to match my battery pack by their capacity... I am not sure that i would use the bad cell for that...
On the other hand, i ovserved that the internal resistor have relationship with capacity. the lower is the capacity, the higher is the internal resistance...
Doc
-measured capacity
Doc
