LockH
1 PW
ESB "No suitable matches were found."... for " Type 506 electric motorcycle"?
These folks "Hand-built in the Czech Republic":
https://cezeta.com/
(They say
A truly unique electric motorcycle for those that live a life a little less ordinary.
Watt some might term a "scooter".
(They say
ACK! See "regen" anywhere? [Sigh]
(and looks hard to pedal...)
https://cezeta.com/
(They say
(They say
A range up to 150 km, with potential to 250 km*. Recharge from the comfort of home from any 110V-240V AC socket with powerful 1.8kW built-in charger.
BODY
Galvanised steel frame with composite body shell and chrome steel trim
Length: 200 cm / Wheelbase: 134 cm
Seat Height: 78 cm / Light height: 15 cm
Seat length: Big to have space to carry your lover.
Wheels: 130/90-13
Weight without battery: 115 kg. Weight with battery: 137 kg (506/01) / 147 kg (506/02)
ČEZETA-TUNED MOTOR
506/01 nominal 5.7kW / boost 8kW offers acceleration 0-50 km/h in 4.5 seconds and top speed of 85km/h (better than a 125cc scooter).
506/02 nominal 9.2kW / boost 11kW offers acceleration 0-50 km/h in just 2.7 seconds and top speed of 120 km/h (equivalent to a 300cc sport scooter).
BATTERY PACK
Čezeta battery pack uses the proven high performance Panasonic 18650 cells (same as Tesla) integrated with the Čezeta Battery Management System. The 506/01 features a 4kWh capacity pack with a nominal voltage of 84V offering a typical range of 80 km -100 km. The 506/02 features the 50% larger 6kWh pack with a nominal voltage of 84V offering a typical range of 120 km -150 km.
CHARGING
Powerful 1.8kW on-board charger enables charging at any standard domestic socket (90V-260V) at a rate of 42 km per hour of charging. An 80% charge takes 2 hours (506/01) or 3 hours (506/02). A charging lead with a Type 2 connector is available as an optional accessory for public charging (see below).
BRAKES & TYRES
Discs front single (506/01)/dual (506/02) and single rear
Combined brake system
Custom disc calipers
Stand-operated parking brake
Michelin Tyres 130/90-13
INCLUDED ACCESSORIES
Crash-detection safety cutoff switch
Powerful 1.8kW onboard charger and 3m extension cable to standard AC socket
Front storage rack
Front storage pocket
Speedometer, tripmeter and state-of-charge gauges
Key switch and steering lock
Two-tone horn
Stand-operated cut-off switch
2 x 5V USB sockets
Baggage hook
Underseat storage
OPTIONAL ACCESSORIES
1/ Windshield - made in Slovakia. Identical to the vintage windshield from the 1950s.
2/ Whitewall tyres - made in the Czech Republic by Mitas, for that classic clean scooter look.
3/ GPS/GSM CAN App alarm - made in the Czech Republic. The ultimate in security to protect your precious Čezeta, connects to the central electronics system and has smartphone App control.
4/ Adaptive headlight - made in the USA, LED 'leaning headlight' with intelligent lean angle compensation on low beam. When leaning and turning the lamp will automatically activate additional LEDs and optics on either side to keep the beam pattern on the road where it is needed for leans up to thirty degrees.
5/ Bluetooth speaker system - made in the Czech Republic. Take advantage of the silent motor to listen to your favourite music. Connects to your smartphone.
6/ Charging lead for use at public charge points - 3m charging lead with Type 2 connector for use at public charge points. Useful if you don't have access to a free standard household socket.
FUEL COSTS
When charged at home at night, the fuel cost (electricity) of a Čezeta Type 506 is approximately half that of a high-performance scooter with an engine fuelled by petrol.
