creativepart
- Joined
- Jun 20, 2020
- Messages
- 14
I have a Specialized Crosstrail hybrid that I built with a Dillenger Premium OffRoad rear hub drive kit.
The bike came with a 2x9 groupset and this included a 9-sp cassette. The kit wheel required a freewheel so I ordered one of those from Dillenger, too. The derailleur and all else is original.
All works great EXCEPT 9th gear. It skips under even lite load. 8th gear works great so that’s what I use mostly. All the gears index correctly and on a stand 9th gear runs fine. It’s just on the ground and it’s skip, skip, skip. Like it’s skipping teeth.
I’ve tried many things. Mostly diy and some with a bike shop tech.
Tested the hanger, put on a new 9-sp chain, adjusted the limit screws again and again.
I tried to put on a different freewheel but it contacted the hub motor and wouldn’t spin.
The bike has 135mm width dropouts and the 9-sp freewheel is a bit taller than the original cassette. Maybe 6mm or so taller.
I’d like to figure this out myself but will resort to a bike shop if need be.
I’m wondering about chain line due to the taller freewheel?? Also wondering if a 7-sp freewheel would be a fix?
Any ideas would be appreciated.
