Kurt
I have been having a bit of a discussion with others on another forum regarding the efficiency of flooded led acid battery's during the final stages of charge 90% to 100% SOC.
The common rule of thumb is flooded lead acid battery's are around 85% efficient when charging from 0 - 100 SOC. Though what I have found is when charging from 90% soc to 100% soc they can be as low as 50% efficient or less at turning DC whrs in into stored energy.
I made the post on a off grid forum as most people including myself that run there homes from flooded led acid battery's tend to use a shallow DOD each day to give long cycle life . Personally I use just 10% DOD but 20% - 30% is also common. Why I mentioned it was because how we off grid people use our battery's. We are always recharging them in there most inefficient range for the battery to accept a charge be it 70% - 100% SOC or in my case 90% - 100 SOC.
I can see this when I measure DC kwh in VS Dc kwh out on my shunts charging from 90% soc - 100% I am just over 50% efficient.
The thing is they all think I'm nuts and don't seem to get the concept :lol:
So the question is... Charge efficiency of flooded led acid from 90% SOC - 100% SOC. From what I'm experiencing and from what reports I have read is only around 50% efficient or less. Anyone know the science behind why the efficiency isn't linear across the range and drops off dramatically as it reaches saturation .
Kurt
Kurt
