So I have a theoretical question. If I made, say a 10S battery pack that used two separate 5S balancing modules (not in the drawing) could I charge half the pack first with a 5S charger, and then just charge the other half when the first one was done? I assume this will work perfectly fine as long you remember to charge both halves up to the same voltage before discharge, but I figured it would be best to ask in case I missed something obvious here.
